End-of-Life F-150 Trucks Get Flashy Treatment with Plastic-to-Graphene Conversion
Flash Joule heating process recycles plastic into high-value graphene for new vehicles.
Ford F-150
Image courtesy of Ford Motor Co.
Rice University chemists working with researchers at the Ford Motor Co. are turning plastic parts from end-of-life vehicles into graphene via the university’s flash Joule heating process. The graphene can then be repeatedly recycled to provide enhanced strength and sound-dampening polyurethane for new vehicles.
The average SUV contains up to 350 kg (771 lb.) of plastic. The goal of the project led by Rice chemist James Tour and graduate student Kevin Wyss, lead author of a paper in the debut issue of a new Nature journal, Communications Engineering, was to reuse that graphene to make enhanced polyurethane foam for new vehicles. Tests showed the graphene-infused foam had a 34% increase in tensile strength and a 25% increase in low-frequency noise absorption. This is achieved with only 0.1% by weight or less of graphene.
Rice graduate student Kevin Wyss holds a vial of graphene and samples of the graphene-reinforced polyurethane made by the Ford Motor Co.
“Ford sent us 10 pounds of mixed plastic waste from a vehicle shredding facility,” Tour said. “It was muddy and wet. We flashed it, we sent the graphene back to Ford, they put it into new foam composites, and it did everything it was supposed to do. Then they sent us the new composites and we flashed those and turned them back into graphene,” he said. “It’s a great example of circular recycling.”
EU car manufacturers must recycle 95% of end-of-life vehicles
Segregating mixed end-of-life plastic by type for recycling has been a long-term problem for the auto industry, Tour said, and it’s becoming more critical because of potential environmental regulations around end-of-life vehicles. “In Europe, cars come back to the manufacturer, which is allowed to landfill only 5% of a vehicle,” he said. “That means they must recycle 95%, and it’s just overwhelming to them.”
Much of the mixed plastic ends up being incinerated, according to co-author Deborah Mielewski, Technical Fellow for Sustainability at Ford, who noted the US shreds 10 to 15 million vehicles each year, with more than 27 million shredded globally. “We have hundreds of different combinations of plastic resin, filler, and reinforcements on vehicles that make the materials impossible to separate,” she said. “Every application has a specific loading/mixture that most economically meets the requirements.”
“These aren’t recyclables like plastic bottles, so they can’t melt and reshape them,” Tour said. “When Ford researchers spotted our paper on flash Joule heating plastic into graphene, they reached out.”
Flash Joule heating vaporizes unwanted elements
Flash Joule heating to make graphene, introduced by the Tour lab in 2020, packs mixed ground plastic and a coke additive (for conductivity) between electrodes in a tube and blasts it with high voltage. The sudden, intense heat — up to nearly 5,000°F — vaporizes other elements and leaves behind easy-to-solubilize, turbostratic graphene. Flash heating offers significant environmental benefits, as the process does not require solvents and uses a minimum of energy to produce graphene.
To test whether end-of-life, mixed plastic could be transformed, the Rice lab ground the shredder “fluff” made of plastic bumpers, gaskets, carpets, mats, seating, and door casings from end-of-life F-150 pickup trucks to a fine powder without washing or pre-sorting the components. The lab flashed the powder in two steps — first under low current and then high current in a heater Wyss custom designed for the experiment.
Powder heated between 10 to 16 seconds in low current produced a highly carbonized plastic accounting for about 30% of the initial bulk. The other 70% was outgassed or recovered as hydrocarbon-rich waxes and oils that Wyss suggested could also be recycled. The carbonized plastic was then subjected to high-current flashing, converting 85% of it into graphene while outgassing hydrogen, oxygen, chlorine, silicon, and trace metal impurities.
Adding small amount of graphene to foam improves performance
Ford has been using up to 60 pounds of polyurethane foam in its vehicles, with about two pounds of that being graphene-reinforced since 2018, according to co-author Alper Kiziltas, a technical expert at Ford research who focuses on sustainability and emerging materials. “When we got the graphene back from Rice, we incorporated it into our foam in very small quantities and saw significant improvement,” he said. “It exceeded our expectations in providing both excellent mechanical and physical properties for our applications.”
Graphene clearly has a future at Ford. The company first introduced it into a variety of other under-the-hood components, and in 2020 added a graphene-reinforced engine cover. Kiziltas said the company expects to use it to reinforce hard plastics, as well.
“Our collaborative discovery with Rice will become even more relevant as Ford transitions to electric vehicles,” Mielewski said. “When you take away the noise generated by the internal combustion engine, you can hear everything else in and outside the vehicle that much more clearly.”
“It’s much more critical to be able to mitigate noise,” she said. “So, we desperately need foam materials that are better noise and vibration absorbers. This is exactly where graphene can provide amazing noise mitigation using extremely low levels.”
