Core-back/MuCell pairing adds strength but takes out weight for automakers
Trexel Inc. (Woburn, MA), inventor of the MuCell microcellular foaming process, and Engel North America (York, PA), a maker of injection molding machinery, are collaborating to develop and commercialize the injection/expansion molding process known as core-back using MuCell.
January 27, 2009
Engel's two-platen injection molding machine
Trexel Inc. (Woburn, MA), inventor of the MuCell microcellular foaming process, and Engel North America (York, PA), a maker of injection molding machinery, are collaborating to develop and commercialize the injection/expansion molding process known as core-back using MuCell.Core-back expansion molding has shown the potential to produce structural applications that feature dramatic weight savings, derived from the ability to redesign parts based on high density reductions (expansion of 50% or more), and resulting in increased stiffness-to-weight ratios.
MuCell enables the production of extremely high-quality plastic parts using precisely metered quantities of atmospheric gases (nitrogen or CO2) to create millions of nearly invisible micro cells in the end product. The creation of these microcellular structures brings a wide array of benefits, including reduced weight, material usage, and production costs, according to Trexel.
Top: Engel offers the only two-platen injection molding machine that has no contact with the tiebars, allowing frictionless movement to better control speed and precision. Botttom: Molten resin infused with a supercritical fluid foaming agent via the MuCell process is injected into a thin mold, where it expands quickly to fill the mold (left). After a certain period of time, the back of the mold is partially extracted (core back) to form the multilayer structure that can be much thicker, but less dense (right). |
Advances in core-back technology are being made to help automakers realize significant weight reductions to improve fuel economy. For example, recent industrial trials announced by Mazda using MuCell have demonstrated the capability to mold parts with weight reductions of up to 30%, and the company announced it will begin using the technology on 2011 model year cars.
In core-back expansion molding, once the foamed resin has filled the mold, the volume of the mold is increased, causing the foam to expand. This results in stiffer plastic parts, with low density and good rigidity, which can be made with less resin. Through a series of industry trials, the combination of these two processes has demonstrated the possibility of redesigning parts in order to achieve dramatic weight savings in structural applications like IP retainers and door panel liners. But Trexel and Engel officials say the process combination is potentially applicable to a wide range of automotive applications.
“When you combine core-back and the MuCell process, you can essentially saturate the polymer with SCF, or gas in its supercritical state, while keeping the mold closed under pressure, and then precisely open the mold to get maximum expansion,” says David Bernstein, president of Trexel. “You get a much thicker part, but one that is much less dense—as much as 75%."
To succeed with core-back, precision molding machine technology is needed. Engel’s duo 1000-ton machine reportedly provides the ability to precisely control both position and clamp force by using its patented design concept for two-platen machines. “We offer the only two-platen injection molding machine that has no contact with the tiebars, allowing frictionless movement to better control speed and precision,” says Steve Braig, president of Engel’s North American operations.
Engel’s duo machines also feature a patented Platen Parallelism Control system. This allows users to control all four corners of the mold’s positioning individually, which, when using the core-back process, allows the tool to be opened for the material expansion part of the process with complete precision. “As a result, we can achieve the necessary precision for running the combined process and achieving dimensionally accurate results,” says Braig.
Bernstein adds, "Core-back technology is being given an entirely new purpose with the MuCell process, and we see a major quality and cost-savings opportunity for our customers.”—[email protected]
